OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Tue May 06, 2014 4:05 am
The engine is a big air pump that needs to inhale and exhale without obstruction to function properly. If it can't properly remove exhaust gasses, correct incoming fuel/air mix and proper detonation will surely suffer. A plugged up cat reminds me of the prank some people would play years ago by putting a potato in an exhaust pipe of a gasoline engine car to temporarily keep it from running.
Matt - Let me post some pictures tonight of the broken pintle caps to see if they look familiar. A buddy of mine recently found a couple of broken pintle caps (on Phase Ii injectors) that were causing uncontrolled fuel flow on his I30. He said it was running bad and getting random misfires. In my case, I found random misfire codes (via OBDII) on cylinders 2 and 5. Wes made a good suggestion about the cats. Does FL still run emission tests as part of the annual licensing process? When I lived in the Tampa area I remember driving the car to some state run emissions testing center to get a certificate to be able to get license plates. I'm not familiar with current FL emission testing requirements. I bought a new Warpspeed Y-pipe and highflow cat for the Maxima that will remedy my cat problems. However, there are no state vehicle inspection requirements here in sparsely populated AR. I ordered an injector refurb kit with new pintle caps, screens, and o-rings to use with some better injectors that came with the replacement engine. My buddy with the I30 sent his injectors to DW in OKC for a refurb and spray testing. He also found a bad fuel pressure regulator. My fuel pressure regulator is new which I think kept the pressure up on leaking injectors that helped the aggravate flooding problem -- go figure.
Wes - What do you think about Matt removing the O2 sensors, so the engine can breathe, for a test drive to see if it makes a difference? Matt - It will be loud and you will need to keep your window rolled down so you don't get sleepy from any exhaust fumes that get into the cabin. This was the temporary testing approach I used to find the plugged up cats.
NOTE: When I ran the test to find the plugged up cats, I took zip ties and secured the O2 sensors to the body to keep them from dangling underneath the car and breaking while I made the test drives. I wanted the sensors to be hooked up to the ECU and not throwing codes while I ran the test. Heated O2 sensors tips do get hot -- so handle carefully. Wes can verify if Stage 3 should be used during a test in the event the ECU ignores signals from O2 sensors.
