1990 nissan ka24e over heating NEED HELP FAST
Bradley Ferguson
Car: 1990 Nissan d21
Ibought a 1990 nissan d21 and now its over heating I replaced the clutch fan and it ran fine for a week then on my way home it over so puled over and looked at the engine the bottom radiator hose was sucked shut so I pulled out the thermostat and it woulonly over heat at red lights so I took but the clutch fan and got a new one and replaced the water pump upper and lower radiator hoses and I took out the thermostat and it is still over heating I flushed out the block and the radiator I kust dont know
Now it over heats while driving down the road so I turn the heater on and that doesnt help
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Sucked shut? as in collapsed? taking the t-stat out will not prevent an overheat, it will just take the engine another couple minutes to reach overheat temps.
Bradley Ferguson
Now I cant drive it more than 15 miles without it over heating I dont understand why it keeps over heating I talked to cousin and he said that itay be a head gasket broke on the exhaust side which is making it over heat
Then some people tell me thr change the radiator cause the problems point the a clugged radiator
Bradley Ferguson
Yes collapsed
whomadewho
Car: 1997 Nissan pickup
If you are driving without a thermostat, the truck is going to overheat. The reason for a thermostat is to allow the coolant to cool down in the radiator before it returns to the engine. I would replace the thermostat, and check the radiator cap to make sure it is not loosing pressure, this can cause overheating. You can also try running the engine (at idle) without the cap and look to see if you observe bubbles in the radiator, if so, this would indicate an internal issue ( cracked head -head gasket - block issue. Take the truck in and have a leak down test done - Simple test and cheap.
Also, make sure you installed the fan facing the proper direction (you'd be surprised how many people screw that up).
How to tell? Start the truck, and see if the fan pulls air through the radiator (drop a handful of shredded paper, grass, talcum powder, whatever in front of the grille and see if it sucks in or blows away from the engine).
Definitely put the thermostat back in, and make sure it's oriented properly.
whomadewho
One last thought - Check the alternator . If the alternator is bad, due to over charging, bad bearing etc. this can cause overheating issues. Check the exhaust system, if it is restricted the engine will over heat.
whomadewho
Make sure you have a good air flow going through the radiator. IF the truck does not have AC, you can take some sort of light, place it in the shroud -fan area. The radiator does not have a thick core so if you look through the grille you should be able to see light. Awhile back I replaced the core support, could not believe the condition of the radiator.
