Duke51 »
https://forums.nicoclub.com/duke51-u212086.html
Sat Apr 13, 2013 7:35 pm
I have it in the shop at my school, mainly to avoid getting weaseled out of money cause i can't say i really trust the other shops in my area, I do trust that they aren't just trying to get money and unfortunately I don't really have the ability right now to get it to the closest nissan dealer to see if they could figure it out. the ecu told me that the knock sensor was bad or that the wiring to it was bad, but that's it no other codes. I put new spark plugs in it, a new fuel filter new air filters a new ptu, took the exhaust off to make sure they weren't clogged. I checked fuel pressure and it's good the injectors are working the CAS works. I had to replace the camshaft oil seals, and when i did that the timing belt looked like it was only a couple months old but i replaced it anyway just to be safe, all timing marks lined up before and after. I doubled checked to make sure that it had not jumped a tooth and it didn't. I've looked on the internet to see if anyone has had the same problem and came up with nothing. I still can't seem to figure it out i even replaced the battery and checked the alternator.
