1990 Nissan 300zx retrofittted with R-134a
300zxcanyondrifter
Car: 1990 Nissan 300zx 3.0L N/A, 1994 Infiniti G20 2.4L, 2000 Mitsubishi Galant2.4L, 2002 Mitsubishi Galant 2.4L, 1999 Chevy Malibu 2.4L
I retrofittted my A/C system with R-134a sucessfully :)
My A/C air is colder great for using it for this summer :biggrin:
nissanfreak12
Car: 92 300zx 2+2 TT
Telling us how you did it and maybe a write up would be very nice!!!!!!
300zxcanyondrifter
nissanfreak12 wrote:Telling us how you did it and maybe a write up would be very nice!!!!!!
Its quite easy, all I did was remove all the lines, evaporator, condenser, remove the
compressor and drains its contents completely, flush out all the lines including the evaporator
and condenser then blow compressed air too remove the solvent contents.
"Dont flush the compressor" !
I ordered a Receiver Drier and a Expansion Valve, and a O-ring kit for replacing
all of the A/C line O-rings.. I ordered these parts from ACkits.com
For the compressor oil I bought Castrol Ester Synthetic in EBay ..
When adding oil into the compressor make sure to remove a drain plug
from the compressor add 6.75 oz, I added 7.00 oz
I bought the adaptors for the Low and High side in Walmart.
Once you installed everything back in the car, With your manifold gauge set Vacuum your A/C System for an hour,
After you are done doing the Vacuum leave your guages still conneted to the adapter ports for an hour check the guages for leaks.
Use a jumper wire to bypass the Compressor Relay. Add one can of R-134a to the suction side, add another can half of R-134a.. Then enjoy the comfort of the cold air of your A/C system :)
robomatic12
Car: 1990 300ZX TT
Perhaps you might know the answer to a couple of questions I have for a retrofit.
Where is the drain on the air compressor?
What were your manifold gauge readings after the system was charged and working well?
