Clean Title
This is not a project, it is a proper fully built car that is extremely reliable. I built this for daily use with some track day experiences.
The only reason I am selling is because I have been offered a full track car that I plan to purchase later this year.
I purchased this stock s13 in June 2018
I fully rebuilt and installed the LS1 with stock T56 transmission in January 2019 with my friend that is a professional mechanic.
This build includes brand new OEM parts anywhere possible (full parts list & service records available upon request).
mileage: 302,118 (on chassis, will change because I drive it occasionally)
mileage on motor is approx 14k
This car does not have AC.
build list, summary:
Engine: LS1 5.7L
Transmission: T56 (6-speed)
Differential: KaaZ 2-way, rebuilt in May 2025
BTR Stage 2 Camshaft
LS7 Lifters
Harmonic Balancer, ARP
Canton Racing deep front sump oil pan
Canton Racing remote oil filter
Oil Pump Melling
Head Gasket Kit GM (12498544)
Head Bolt Kit GM (12498545)
GM OEM LS1 Ignition Coil Packs (19421259)
Spark Plug Wire set, AC Delco (9748CC)
Wiring Specialties Pro Coil Pack Harness Set (WRS-PROLS1-COIL)
Fuel Injectors Flow Tested and Cleaned (Jim at ProFlow)
Driveshaft custom made at Dependable Driveshaft in Clearwater, FL
Apexi WS2 cat back exhaust, THMotorsports (115-KN06)
ISR Performance Exhaust Y-Pipe (IS-240LS-Y)
ISR Performance LS1 Swap Headers (IS-SSHD-240LS), ceramic coated
ISR Performance LS Engine +T56 Trans Mounts (IS-240-LSMK)
Energy Suspension Universal Engine Mount Bushings (9.9489G)
Energy Suspension Transmission Mount - GM (3.1108G)
Clutch Kit LuK 04-905 LS7 with flywheel
ISR Performance T56 Clutch Line Bleeder Block (IS-T56-BB)
ISR T56 Slave Cylinder to Bleed Block (IS-240-418)
ISR Performance Clutch Master Cylinder Adapter Plate (IS-MCA-S134)
ISR 240sx T56 Conversion Clutch Line (IS-240-LO419)
Wilwood GS Integral Reservoir Compact Master Cylinder (260-15098)
Short Shifter MGW F-body Camaro/Firebird
Shifter Knob official OEM Ford Mustang Cobra (M-7213-B)
Wheels Enkei RPF1 17x9 5x114.3 +22 Silver Paint (3797906522SP)
Tires Falken Azensis RT660 (245/40ZR17)
Hub Conversion, Front & Rear, 5 Lug, ISR Performance (IS-5LG-KIT)
Fortune Auto 500 Series Coilovers (FA500-S13) 9k front springs / 7k rear springs
Rear Upper Control Arms, ISR Pro (IS-RUCA-NS134-PRO)
Rear Toe Control Rods, ISR Pro (IS-RTC-NS134-PRO)
Energy Suspension Rear Subframe Bushings (7.1117G)
Front Sway Bar Tubular 240sx with LS1 32mm Sikky (SB101)
Wiring Specialties Engine Harness LS1 (WRS-PROLS1-S13)
Wiring Specialties 5-point grounding cable
Wiring Specialties PCM/ECU (0411)
Dakota Digital speedo box (SGI-5E)
Radiator Koyo N-Flo for S13 SR20DET (HH020252N)
Mishimoto Fan/Shroud (MMFS-S13-89SR)
Radiator fans, SPAL (Qty 2) (SPAL 30102038)
Thermostat 160F Summit (SUM-363-160) *OEM was 187F
Fuel Pump: Walbro Fuel Pump 450 LPH (F90000267)
Fuel Pump Wiring Kit (Wiring Specialties S13 240sx Plug and Play Fuel Pump Relay Kit, WRS-S13-FPK)
Fuel Filter/Regulator Speedway Motors (910-12807)
Alternator AC Delco (335-1075)
Starter ACDelco Gold (337-1115)
Water Pump (AC Delco 252-846 / GM 19195105)
Power Steering High Pressure hose, P2M (P2-PSHN240LS)
Power Steering Flow Restrictor, TurnOne (T1115)
Power Steering Rack Bushings, Energy Suspension (7.10104G)
ISR Solid Steering Shaft Bushing (IS-SSB-NISS)
K&N High Flow Air Filter (RF-1045)
AC Delco shift lever dampner, brass (14105942)
Hood Damper/Strut, P2M (P2-BHDNS13-TP)
Oil Catch Can (Mike Norris Motorsports Billet)
Power Steering Cooler Dorman (918-304)
Brake Master Cylinder Z32 upgrade for s13, TF-Works.com
Brake Booster for s13 ABS Duralast (53-2550)
Brake Master Cylinder Heat Shield, S13, Circuit Sports (BHS-0134-GD)
steel brake lines front and rear
Dash Cover, Coverlay (10-890-BLK)
Tune by Chris at CHenry Motorsports in Dade City, FL
Fluids:
Engine Oil - Valvoline VR1 Racing Oil SAE 10W-30, filter FRAM PH8A, 7 quarts capacity w/filter change & remote oil filter
Transmission - Valvoline ATF DEX/MERC (DEX3) fill & drain plugs are 20 ft lb torque, 4 quarts capacity
Power Steering - Redline 30404 full synthetic power steering fluid
Brake - Motul RBF 600 DOT4 Racing Brake Fluid
Clutch - Motul RBF 600 DOT4 Racing Brake Fluid
Differential - KAAZ 2-way LSD Gear Oil (GL-5/80W-90) *fill & drain plugs are 40 ft lb torque, 1.5 liters capacity
Radiator - Distilled Water with Redline Water Wetter
Asking Price $25,000
Located in Tampa, FL
