My questions is: After I buy a motor set, what else do I need?
This is going to be my first time ever building a car, so what better than a 240sx.
(SR20DET Blacktop)
Motor Set Includes:
Complete Motor
Complete Head and Block
Intake Manifold
Injectors
ECU
Uncut Harness
Fuel Rail
Power Steering Pump
Throttle Body
Exhaust Manifold
Alternator
Turbo
Starter
5 Speed Transmission
Clutch Disk
Flywheel
I know some other things i will need ar going to be:
Battery
Radiator
Intercooler
After that im not sure what else, do you guys mind helping. Its basically just going to be a daily driven car and maybe street raced.
Do you have to have an intercooler in order for the motor to start? If you run without one will it hurt the engine?
Ive read that its just that heat and whtever, but what if my car doesnt have a hood?
Will i be able to atleast push 270hp with boost turned to 11psi and some other basic mods?
Any other things i should consider? Thanks in adanced.
