1990 Nissan 240sx: Rear Defroster Not Working
bpp1991
Car: 1990 240sx
Had to use my defrosters for the first time this morning, they all worked besides the back window Is this any easy fix? What's the problem? Thanks
vancouverbc
Car: 1991 240sx
I had the same problem with my car - all fuses good but still no rear defog. After checking with a voltmeter, I found that the defogger was not getting power. Turns out the wires to the defogger had broken right where they leave the hatch and enter the body - they kink right there and mine had finally broken. Its a relatively easy fix, but you do have to pull off the interior panels in the rear seat area to get at the wires, then its just a matter of splicing in new wires. If this doesn't turn out to be your problem, it may be the wires in the glass - the FSM has a procedure for checking these. Hope that helps...
vancouverbc
Car: 1991 240sx
http://www.nicoclub.com/FSM/24...R.pdf
just click on tutorial link in my signature and go to factory service manual
