PapaSmurf2k3,
Thank you for your help in my plight!!!
Earlier today I took the car down and got it smogged and to my surprise, the smog tech was adamant to comment on just how well it passed for the millage (>250,000miles).
However, ironically enough, once the car passed smog and the smog tech turned off the motor, the car would no longer start.
I was able to get a jump start and took the car back to my friend's house to diagnose the problem.
With a voltmeter on the battery, we tried to turn over the engine. The volts dropped from approximately 12.8 to 0.1; the battery was toast.
We then proceeded to install a functional battery. Afterwards we started the car and checked to see that the alternator was charging the battery; it was. While the car was running, it read 14.6 volts and would rise a bit upon acceleration. From this we inferred that the alternator was functioning as it should.
However, while the car is at rest, with the positive battery terminal connected, and the negative battery terminal disconnected, there is an approximate .067milliamp drain going from the negative battery terminal to the ground strap. Because of this, we resorted to leaving the battery disconnected until we could identify and remedy the drain.
Q: Do you have any suggestions for how to diagnose such a battery drain? We were thinking about going through the fuse box and systematically pulling fuses until we could see that the battery drain cease; using this strategy as a guide to pinpoint which section of the electrical system to target.
Thank you in advance,
-Brian
