1990 Nissan 240SX - Cluster NOT working
stonb
Car: 1990 Nissan 240SX
Hello,
I recently purchased a 1990 manual 240sx, the car is all stock, but from the whole car the only thing that was "out" of normal was the cluster, it is white which kind of caught my attention.
The car need some repair but it does run and it is drive able, but the cluster does not work at all, not a single light turns on when I start the car nor when i drive it, all the instruments are death.
Can you guys give me a help, i am trying to find out how to fix it, or where can i test if it is working?
Also, i already went to a local u-pick place and they have a cluster for a 1989 automatic 240sx, would this work on my car?
Thanks,
I am attaching some pictures for reference
esd51918
Car: 1989 Nissan 240SX Coupe
The '89 cluster should work, but for nothing to be working on the existing cluster I think there are other problems. Check yours fuses, then pull the existing cluster and start checking connectors.
stonb
esd51918 wrote:The '89 cluster should work, but for nothing to be working on the existing cluster I think there are other problems. Check yours fuses, then pull the existing cluster and start checking connectors.
Thanks for your answer, I went and check the fuses and they were blown :facepalm: , so i changed them...
Sad news is that they blew again, with and without cluster, so now i will have to dive in into the wiring to see where the problem is... :gotme :mad:
