ChromeSkull »
https://forums.nicoclub.com/chromeskull-u164313.html
Sat Oct 02, 2010 8:57 am
Ive managed to fix my Climate Control.
It is a massive PITA, took me all of 20mins to sort it once i found where it was.
Mine was a corroded connector and just needed unplugging from the fuse block and spraying the pin with some cleaning alchohol.
The wire on the fuse block side is located as follows.
on the very top of the block above the fuses there are 3 large connectors, 1 black 2 blue. it is the middle blue connector. without removing it, the wire is Green with a silver stripe 2nd from the top (there is only 1 wire there the very top has 2). that is the wire that i cleaned and pushed further on with a small screwdriver.
give that a go.
