everpresentnoob »
https://forums.nicoclub.com/everpresentnoob-u268012.html
Sat May 27, 2017 6:07 pm
Ok, where to begin. Fixed the AC last weekend and finally put a belt on it. AC worked great. Driving to work on Friday car was running great. suddenly out of the blue it started backfiring, surging, popping and generally loosing power and running like crap. managed to limp the last few miles to work. When it was acting up, trying to get out of the fast lane on the interstate in 5th gear, flooring it, but the car was still slowing down from 70mph. Yea, I know, I shouldn't have been trying to floor a motor running like that, but it was that, or get nailed by other cars. Limped into the parking garage at work and it would not idle. Stop lights and stop signs the last two miles were an exercise in playing with the throttle and the hand brake. FYI, the hand break alone will not really stop you from 40 mph....
during the work day I managed to go out and do basic troubleshooting... Checked ECU for codes, there were none. Pulled a few connectors apart, but they didn't look to bad (MAF, PTU, TPS, coolant, coils adn injectors). basically couldn't find anything glaringly wrong with it. That afternoon when I fired it up it idled perfectly. took a chance and started heading home with it. 83 miles. first 25 are in generally stop and go traffic. Car ran like a dream. well mostly. Last quarter mile it would occasionally hesitate as if the fuel or something were cut suddenly and then it would pick back up a second later. It did that a few times.
went out to it this morning and fired it up. Chugging pretty badly and running rough. just like when I had a dead injector. Sure enough, middle one on the passenger side was dead. Replaced it with a spare used one I bought from a guy here. Car ran pretty good. took it on the road and it still had the occasional hiccup.
I replaced the fuel filter as I was thinking it may be a fuel issue. continued to clean some corrosion off a few of the connections. Pulled the AC belt back off in case the AC compressor was seizing momentarily and dragging down the motors RPM. Took it on the road and it was running fine. drove for about 30 miles. all was good until suddenly it started acting up again. Almost didn't make it home.
Got it back to the house and started searching for things that could cause it. Came on a post about the TPS. Ok, went out and used my meter to check mine. On the TPS plug when you check ohms on the two outer pins the resistance was 9000. with in spec. inner and the outer black wire ohms should be 1000... Mine was 345. Ok, that dosent seem right. Read a number of threads here and on TT.net about it and determined that my TPS was not within spec, so I replaced it. Put the new one in and all the tests worked out. got the voltage from the middle pin to ground to be .45.
Car now holds and idle for about a min, then does its popping, breaking up thing and drops to almost stalling, then surges to 1500 and steadys out at 850. it is still undriveable though.
After all this I thought to check for codes again. 34, Det sensor.... ok, cleared it from the ECU and drove it around about 5 miles. not smooth at all. Still doing the same thing, although not quite as bad, but definitely not trying to actually depend on it to get me anywhere like it is. Got it home and checked codes again to see if 34 came back, but nope, no codes.
I am about at wits end here. what else should I check? I can get a new Det sensor and harness from Concept z for 75 bucks, but if that aint the issue I dont want to do that. Car is stock, mostly, just a cheap catback and a k&n filter up front.
