http://www.300zx.co.uk/cgi-bin/manual.cgi
Section Engine Fuel & Emissions Control page 179
If the terminals are green, make sure you scrape all of it off all pins on all connectors, then use some good contact cleaner. That green stuff keeps it from making a connection and it won't run, or run right. If some show it, good chances they all might.
Check: PTU, CAS, MAF, Coolant Temp, Injectors, FICD, Aux Air Valve, Fuel Temp,
Modified by Zwicked at 9:28 AM 7/18/2007
