DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Mar 09, 2018 9:22 am
You will want to use JWT injector adapters if you didn't (pretty sure CZP carries them as most Z32 vendors do), they are the correct option for using the old fuel rail with new style injectors and they also do a little improvement regarding excess fuel accumulations at the injector tip.
Did you replace ALL fuel related items such as fuel pressure regulator, etc.? If not, do so for best results on a 25 year old car.
Do check the O-rings again, they are notorious for problems and problematic to install correctly- I've read of some people who took quite a few tries to get it right, including reports of issues from a few repair shops.
The fuel rail should be fine if no leaks, and I assume you used injectors bought from CZP as well? If not perhaps a revisit checkup of them is in order and also checking to be sure you have the correct size and style.
Oh, and the FSM also has info and help/tests for the fuel system and injectors, it can be your friend for sure.
Hope this helps!
