Over the last 6 months i've been getting parts together and i'm finally ready to start working on a new project.
My hopes are to build and race an N/A in my local autocross while i get used to the chassis and then start the tt swap when i feel comfy.
I have two n/a z's to start with but one is rusty as hell and i'm not sure it can be saved. It does however have a whole lot of parts for me to use.
I'm in my 30's but this is my first real "sporty" car and i'm just learning how to drive with rwd so the N/A is plenty of power for now but just like everything it won't be soon enough.
I did build a rally car in the past and raced it with a local chapter of SCCA but it was a subaru legacy and i wouldn't really call it a sports car.
So here we go.
The car i'm building is the gold z and the blue z i'm going to make run with all of the spare parts that i'm no longer using as i build/swap it. What will i do with ol blue when i'm done? who knows?
I'm super cheap so i will document prices as i go so everyone can see what being such a cheap a** will get you.
The blue z : 500.00 not running
the gold z : 1000.00 pissing water everywhere
new water pump and hardpipes: 100.00 on cl. great find.
AMS underdrive pulley : 75.00
Stillen Headers : 150.00
s*** aftermarket radiator : 50.00
Twin Turbo long block incl. exhaust manifold and turbos : 500.00
So Original Bill of 2,375.00 not including tags or emissions
First things first i wanted to see how bad the blue z was. I started tinkering and the only problem i found was a starter that had been incorrectly shimmed. It wasn't catching the flywheel. After a little wrenching it ran and drove fine. This was unexpected with the condition of this car (and considering the previous owner stated it didn't run). Since i now had 2 z's and 3 motors 1 had to go. I pulled the blue z's vg30de and it sold on craigslist in 4 days for 500$
So i'm back down to 1875.00
Now to the gold z. I replaced the water pump and hard pipes and put the underdrive pulley on and slapped it back together to see how it runs. It's pretty quick and loses the back end nice and fast. All of you tt owners can make fun of me all you want, but it seems like a lot of power compared to my ej22. The only parts i used during this process were already documented above and a minimal amount of gasket maker. we'll call it zero dollars.
Additional work that the gold z has
egr delete
aiv delete
The little throttle stop pin delete
ebay intake with the little bug looking foam like air filters
HKS hi power exhaust
shotty looking short shifter
All of this was done by the previous owner(s) so zero dollars.
I pulled the ECU and it looks like it's been out before but i dont see any sort of markings on it implying that it's been chipped and i don't visibly see any difference from stock.
So now that it's running well and not leaking i went off to emissions.
And i failed miserably!!!
High HC's and really High CO, i will post a pic of the test results.
That's where i'm at now, figure this would be a good time to start documenting the build and ask my first questions.
I seem to be getting a whole lot of unburned fuel to my 02 sensors.
Any of you experienced with having to get emissions on an engine with the aiv and egr delete?
Is it even possible to get this little monster to pass without reassembling those tedious little systems?
The charts posted seem to point to a lazy o2 sensor to me but i'm sure there is someone out there that is better at debugging these 5 gas analyzer results
I'm going to start with a tune up because who knows what the last owner did with this thing. I'm going to start with an oil change, plug change, and new 02 sensors. The timing belt is coming i just did the water pump so i could play with it a bit before i do any big work.
I left all of the timing covers off for now.
I think that's it, a bit long winded, but details make the story; right?
So. pics.
