slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sun Aug 19, 2007 2:53 pm
Hi folks,
I just bought this car, 160k on the clock, and this series of engines are all new to me. I'm plenty good with the KA series of engines, and I think a lot of the same principals apply here also.
Anyways, the car has a pretty rough idle, enough to vibrate the engine, but not severe like a crossed plug wire. When I manually actuate the EGR valve, it smooths down to almost a pur! This means by ingesting more air, the idle is smoothing out: this implies the mixture is over-rich? No smoke, but the exhaust does smell of fuel. From the vac diagram this should be correct: apply vac. to direct gas into the intake mani.
I was under the impression the EGR should *not* be active at idle, but will if RPM is raised(no load). SO, perhaps a leaking injector? The head temp sensor was disconnected, so I tested that and reconnected (after cleaning and "re-springing" the female terminals for a better fit).
I've squeezed the IACV bypass hose, engine speed decreased, as I would think it should(?).
I let the car guzzle about a 1/2 can of seafoam, and it seemed to help a little, but still a bad idle. Lack of power also.
I know this is all really vauge, however, I'm not used to diagnosing an engine without a computer interface!! I know enough though to tell it isn't running right.
BTW: can anyone tell me, can the "checker box interface" connector be used to put the ECM into the 5 different modes? Is it worth messing with over the potentiometer on the ECU itself?
Thanks for reading.Jamie
