Hey, any help on a no start?
I'm working on a 1990 Maxima 3.0 V6 5-speed carthe car was running fine untill oneday it just stoped and would not start.It was if the Fuel pump wasn't priming? so replaced with new pump,still no start..checked relays to fuel pump and jumped relay fuelpump runscranked over no start.. checked ditributer, checked coil(replaced), checked that cam sensor resistor(very pricy by the way) and all conections(all good and getting power to the injectors but no start...) throttle position sensor???in my shop manuel it shows the ECU with it's red and green test lights.(I've tried everything else I'm thinking...does the ECU go bad..)pulled harness off getting power to pins, I turned the screw clockwise to start test and a red light is saposed to flash no flash? I realize this is an oldie just wondering if anyone knows how to test the ECU to see if it's dead? 100 Bucks for a yard ECU if I don't have to I'd rather not.. any tricks?
