1990 KA24E Manual Trans TPS
mick
Car: 1990 240SX
The TPS has 3 wires coming out of the top. And there is a plug with 2 or 3 wires which faces the firewall. My car only has 2 wires. What do those wires do to the TPS?
Gabes13
Car: rb20det s13
take a pic or draw a picture and I can help. usually its 1. power 2.send and 3.ground
mick
Car: 1990 240SX
Here is the photo Where it says 2 wire plug---I have 2 yellow wires and a green that I don't use.
Is this plug just for high rpm changes to the TPS?
Gabes13
Car: rb20det s13
yeah that green wire is the ground for the tps/idle switch. you might even be throwing a code (43?) indicating tps error or something like that. If not, I bet your idle is all weird.
looks like someone got happy with knife on your harness.
mick
Car: 1990 240SX
pandapants wrote:yeah that green wire is the ground for the tps/idle switch. you might even be throwing a code (43?) indicating tps error or something like that. If not, I bet your idle is all weird.
I have one green and two yellow wires. I have a CEL the first 4 minutes after starting then it goes off.
So I'll just ground the green wire?
Gabes13
Car: rb20det s13
mick wrote:I have a CEL the first 4 minutes after starting then it goes off.
what is it?
mick wrote:So I'll just ground the green wire?
yup.
mick
Car: 1990 240SX
The last time I checked the CEL gave a code for the TPS sensor. That must be the ground problem
Modified by mick at 5:17 PM 5/28/2009
mick
Car: 1990 240SX
I wired the green/black wire to ground and now my CEL is always on.
