1990 KA24E, God awful noise!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so I did the headgasket on my 1990 KA24E, 69k miles the head was out of the car for about two days sitting on a clean towel, I put everything back together and she started right up, my problem is I hear a VERY loud metalic tapping noise coming from the head, it sounds like you're tapping two pieces of metal together. It it is RPM dependent (higher RPM faster rate of tapping, lower RPM lower rate of tapping) it's a NASTY sound. I ran the car for about 15 minutes and it did not go away, if you take off the oil cap when it's running little bits of oil spit out, the head does not seem like it's starved for oil... is it one of the lifters tapping because it drained while the head was out of the car? any other ideas what it might be? the car seems to run and rev fine (all the way to redline) .... Help...
I'm going to go see if I can get a sound clip for you...
navysnail
could be lifters, but running the car for 20min is the procedure for bleeding the air out, so i doubt that is your problem. can you try to find out exactly were it is coming from (front, back, whatever)
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Video and sound clip found here: http://q45.spilky.com/gallery/....html
babowc
Car: 240sx
maybe.. its the valves hitting the pistons.. i dont think thats very logically possible though.but im a newB.. so...
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Rod exited the block today.. case closed..
180fan
Car: 89 fastback
Yikes.
