spindrift187 wrote:For the intake: If you have any friends that can weld id recommend making your own, im sure it's a hell of alot cheaper than buying one. I noticed a great throttle response when re-locating my battery to the trunk and routing the intake through a hole where the battery tray used to be.
thats exactly what i did. total all parts costed roughly 100buxive done this so far 3-4 times and what you need is 1 ram air intake from a 94 integra (ebay
http://cgi.ebay.com/ebaymotors...ZWDVW)2 a maf adapter with filter. (ebay)
http://cgi.ebay.com/ebaymotors...l13183. extra 2.5in to 3in coupler (i used 4dollar rubber one from homedepot pvc)
after battery is relocated use either a hacksaw or dremel or die grinder and juts cut to fit. then be carefule doing this but cut the maf signal wire CASING and then pull it to where it needs to go then RETAPE EVERYTHING GOOD. so nature doesnt affect it
battery kit 12-15 ft 2gage or better a distribution block not needed but nice to havehttp://
www.tti-plus.com/Bluewa...2.htm 200amp breaker (saved the coupe once so far got stuck in a serious..puddlehttp://cgi.ebay.com/CIRCUIT-BR...l1247plus battery mounting tray and holddowns or batterybox
then i followed this guide and made lil changes particular to mysetup.
http://www.nicoclub.com/articles.php?id=196280
pics of my setup as inspiration
also since the picture was taken i have wired in the amp/distribution block/and efans
