Chaddoes »
https://forums.nicoclub.com/chaddoes-u258932.html
Fri Apr 28, 2017 9:43 am
Hello Everyone,
I usually watch from the shadows as I can search and find my answer on my own but I figure I would finally give posting a shot.
To make a long story short, I purchased an recently deceased man's project car.
it was a full puzzle car, no engine in and two partially built engines and 2 transmissions came with that car.
(yay spare parts!) all unknowns.
I am on year 2 of this project, and I finally have an engine built and in the car. (engine in and out 3 times before finally giving in a doing full rebuild)
I am afraid that I may have done too many changes and deletes to make things work smoothly in my favor.
I have done every delete recommended, and during the engine rebuild, I have increased the injector size to the yellow nismo 615's along with a new fuel rail and matching new style / old style connectors and seals to make everything match.
I have an AT, and had to use my original ECU as the MT ECU's (have extra ones) apparently are not backwards compatible with my AT, so I socket-ed it and dumped my original base-map into nistune, I then used the injector resize to create two different builds (one is allowing nizstune to adjust all the maps, and the other is an injector resize only)
I then loaded them into a pocked romulator and did another consult dump, to confirm the romulator was running correctly and the dumps match %100.
I set the cas to 15 for timing, my MAF is .8v and has a cone filter.
Now to get to the point:
The car turns over, starts, revs up and dies 2 seconds later.
if I adjust the throttle stop, I can get the car to idle at about 1200 rpm.. it runs for about 10 seconds and then starts idle hunting. (throttle never shows full closed in consult when I use this method).
still learning how to tell if vehicle is running closed loop or not.
I did the Idle Air Control valve cleaning job with WD40 and tried adjusting it's screw both in and out.
The car doesn't change more then about 150 rpm when I unplug the IACV. (I will ohm it out tonight)
I sprayed brake cleaner around for possible vacuum leaks but haven't found any yet. (unless it's the plenum)
I am wondering if more work needs to be done in nistune such as injector latency.
This weekend I will confirm every injector is working as I just assumed as I bought them fairly new.
Thoughts?
I have no bad codes, I did the EGR Delete using plates and vac plugs, but no resistor, I cut out my exhaust temp probes for new aftermarket pipes (yes the full jspec JDM's have exhaust probes) not sure if I should put resistors there either, but like I said, no codes other then the all good code.
I timed the engine using tooth counts, as the back plates had separated and had movement and I couldn't trust them (timing marks).
-Chad
