loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Feb 24, 2010 9:04 pm
If you have no record of prior flush, most shops will refuse to do the ATF flush due to liability issue. If you have transmission issue, it would be a good idea to do a pan drop, clean the pan and magnets and inspect the filter and replace as required. After the pan drop, you can do multiple drain and refill to emulate a flush (not as good as a real flush, though).
