90T04 »
https://forums.nicoclub.com/90t04-u29731.html
Thu Jun 16, 2005 3:25 pm
Hey guys, I was wondering if there are any common failures associated with this problem on Infinity's.
The car is a 1990 M30 and it has the 3.0L V6.
Im a technician but i dont normally work on Infinity's, I am working on it for a friend.
Here is a description of the problem:The car starts up great first time in the morning when its cold. After you get where you are going, and and lets say you go in the store and come back out, the car will not start, just cranks. Its cranking good and fast, battery has plenty of juice. You have to crank it maybe between 5 and 15 times before it will fire up. Once it does start, it runs absolutely perfect.
The problem is getting worse and worse, lately it has been taking a lot of cranking and were getting worried it will take out the starter.
I have heard some things about the "FPCU." Is this a likely culprit?
The only other thing I can think of is that it is boiling the fuel in the rail while it is sitting and the engine is hot.
Thanks in advance!Ryan
