1990 HB Truck erratic idle
Colorad0
Hello I have a 1990 HB truck 3.0 v-6 multi-port fuel injected 4x4 manual trans. The truck was idleing about 2000 rpms I thought it was the throttle position sensor so I changed it now the engine idles erratic goes from 2000 rpm down to 1000 rpm and back continuesly any ideas what is causing this I was thinking 02 sensor or maybe mass air flow sensor (please keep in mind this is multi-port fuel injected NOT throttle body) Any ideas would be greatly appreciated and Thanks in advance for any help
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Idle Air Control Valve, or IACV, sounds like it is failing.
