xhighfidelityx »
https://forums.nicoclub.com/xhighfidelityx-u161383.html
Wed Jun 09, 2010 8:53 am
That is a tachometer and clock wiring. One is for the tach and one is for the clock. I could not figure out how to get the tach to work even though I found a tach at the junkyard. The clock in it worked great though, so what I did was cut a square in the blank face so the clock will show through it and took out the tach. I figured it would be better to have an aftermarket tach in the future someday than try and figure out the wiring to get the tach to work, if that make sense. So with the clock hooked up, the tach plug is left dangling. They only thing I could figure out is the 4WD models had different bundles connecting to the coil, so I think that is why the tach doesn't hook up properly. I hope that helps, but I know for a fact that the wire bundle is for the tach and clock.
