BeyondBiscuits2 »
https://forums.nicoclub.com/beyondbiscuits2-u45101.html
Mon Jan 29, 2007 7:38 pm
I assume you are attempting a GA16DE twin cam swap on your GA16i single cam B12 Sentra? If you are, then you will not need a new crank, both GA-series engines have the same crank. In terms of switching from an auto to a manual transmission, you will need to get a flywheel, and ditch your flexplate. The hardest part about the swap is the wiring; the engine is a direct drop-in.
