NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Feb 07, 2004 11:24 am
Flywheel flywheel boltsclutch kit(pilot bushing,T/O bearing,disc,pressure plate)clutch master cylslave cylclutch linesclutch pedal assemblyharnesses for trans and possibly the engine room harness.probably manual trans ECMI believe the transfer case will be a direct bolt up from auto to manual trans you will need to swap the 4X4 shifter guide from auto trans case to manual trans case.
