Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Fri Mar 07, 2008 9:36 pm
If youare staying stock just go to your local chain auto parts store and buy the pre-made cables that will be long enough. Just mesure the length you have and add a little. The molded on connectors are much better to use they provide the best connection.
When you connect the ground wire to the car be sure to clean the mounting location. A dirty ground connection,even if it is tight, can cause a lot of problems that are hard to figure out.
