1990 300zx wont start,wont crank but lights work
1990Z32
Car: 1990 Z32 300ZX
i had my 1990 300zx running for 3 days perfectly fine, today i went in the lights in the inside turned on but shut after i closed the door then i turned the lights and high beams and they both turned on. my battery is perfect. but my car wouldnt show any power. wont crank and when i "attempt" to turn the car on when the lights are on they do no dim. ( i just got new spark plugs yesterday...)
Thanks, Sam
greendusk
Car: 1990 300zx TT Pearl Glow (5 Speed now after swap)
1990 300zx NA Black Auto(Sold)
1990 300zx NA Purple 5 Speed(Engine Washed /Sold)
2001 Stratus (Scrapped)
My car was doing that after I pulled the plenum. I jumped it and it worked fine.
1990Z32
Car: 1990 Z32 300ZX
i think it was the weather from last night cuz it was cold , it started up perfect this morning no problems but what happened last night do i need a new starter ?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
If it happens again, check the starter by hitting it with some kind of bludgeoning device. If it starts afterwards, your problem is the starter. If you have a manual transmission, it could be an intermittent short/open condition on the clutch safety switch. Likewise, if Auto, a neutral safety switch (though the Neutral Safety Switch is not likely to fail).
