300zxtwinz »
https://forums.nicoclub.com/300zxtwinz-u220833.html
Tue Sep 03, 2013 10:22 am
Okay so I've been working on the TT a lot, here's my situation, I have done the following, under plenum coolant bypass, I think this has no effect.
Aiv Delete
Egr Senoid Delete
Egr delete has been done previously
And Carbon canister Delete.
PRVR is still in place and connected.
So I'm running to a few vacuum like hose placement problems..
I have the boost sensor directly connected to the balance tube and the fuel regulator directly connected. To the balance tube in stock location, and the other nipple I have plugged bc i can't figure out what to put there. Any way so on the driver side I have the one nipple on the balance tube going into the plenum like a closed loop. I have no Idea how else to do it and the prvr is connected tovthe lite hexagonal nipples. My vacuum lines for my records are not connected to anything, because when I connect them in anyway the motor surges pretty bad, if I change anything around it surges a lot.. It's so confusing because the recircs still vent the air. I have them venting tovthe atmosphere. Just because... I do have a det sensor bad but I'm replacing that this week. Can someone help me out with some sort of diagram??
