Just bought a barn find 1990 300zx TT (automatic atm) that has been sitting for multiple years (but has only 42k miles
I've replaced the fuel injectors to new style with the Z1 kit.
Replaced most of the hoses to silicone hoses (also Z1 kit).
Did both a compression test (all cylinders +/- 2 psi of 155psi) and a fuel pressure test (~36 with ignition on, 43-50psi at idle).
Also emptied the old gas and filled her up with some fresh 93.
The car will turn over but needs about quarter throttle to keep running most of the time. If I let off the throttle it stalls out almost immediately unless warmed up in which case it will idle for a bit. The fan will kick on pretty high if I give the throttle a blip. The engine also won't go over ~3-4k rpm.
I'll be doing a timing check and boost leak test soon but was wondering if there are any other obvious things that might be causing it to run so roughly.
Possibly a faulty coolant temp sensor? PTU? (still has old model PTU) Any other things I should check?
Thank you ahead of time for any help. This is the first 300zx I've owned but am already falling in love with the car. I just want to get her running right again.
