Jiinx wrote:When you set the timing light advance to 15 degrees, what are you reading? ( the pointer should be at 0 degrees)
How does your car sound like when it's running? Does it seem to run fine?
thank you soo much jiinx i did what you said got my timming set,engine sound fine when turned on and runs fine but still lags a little when starting in first gear dont know what it is any help appreciated
Ive changed all of this to my car...
spark plugs ngk platinum
changed shocks
idler pulley
master cylinder
slave cylinder
tps
thermostat
new style injecter connecters
changed 3 injectors and put new orings
exhaust cam covers were taken off and resealed with ultra grey rtv
relocated denotation sensor
