evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Nov 27, 2006 6:17 pm
first step is to check for a charge, if it's got a charge, then add refrigerant up to specified pressure, if it's really low the system won't work, if you have no pressure, you need to get the system vac's adn try to find the leak, fix the leak and charge, first things first, is there ac charge and is it up to spec or at least close
