A small leak on the front seal of the A/C compressor. They claim the oil was a clear color and wish to replace the A/C compressor. As it stands right now the A/C blows cold and works just fine. They want 380 for a Re-manu compressor and 430 for labor.
They also found a small oil leak which they suspect is the front crankshaft seal. They want to replace seals. While they're under there they recommend replacing the timing belt. 30ish for seals and 700 for labor. The thing is, 7k miles previously the car had the engine rebuilt and when I looked at the car I didn't notice any oil below it or on the motor.
Thanks in advance.
Allen
