Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Tue Nov 01, 2005 6:19 pm
Well, I would make sure the mafs is getting power, then clip the signal wire with enough length to extend the signal wire all the way to the ecu just to make sure. What this is sounding like is it's either a bad mafs, the wrong mafs, bad signal wire, or no power to mafs. The reason being is that once the mafs is hooked up, it thinks so little air is comming in, it basically shuts off the fuel. So chances are, it may not be getting power. Check with a voltmeter to see if the mafs is getting power, if it is, I would suspect a bad signal wire, perhaps. It's definately the mafs though by how your post went.
