1990 300zx na wount start
eloyito
Car: 1990 300x
Hello everyone I'm new here and I was wondering if anybody had a problem like mine.. well here it goes my nissan 300zx ran fine but the next day no start.. i have fuel, spak, compression. And i checked the timing what could it be if anybody can help me plz
PapaSmurf2k3
Site Admin
Maybe your timing belt jumped a tooth or 2? Does it sound weird when you are turning it over?
eloyito
Car: 1990 300x
It sounds like it has no spak or fuel like when u crank a car but it wount start because theres no fuel but spark plugs come out wet
PapaSmurf2k3
Site Admin
Are they wet with fuel or something else?
Have you tried just spraying some starting fluid in there and cranking it? Have you actually pulled a plug and checked for spark?
alms24sebring
'04 Nissan Sentra SER SpecV
First dibs on your front calipers. seriously...
Is it wet from fuel? You may have drown them out with gas from trying to start, so it has fuel unless its so much coolant leaking that it kills the motor, but not likely. Dry them off and try again. Could be something electrical like a crank sensor too. Make sure the battery is strong too.
Dattebayo
eloyito wrote:It sounds like it has no spak or fuel like when u crank a car but it wount start because theres no fuel but spark plugs come out wet
Well that's just confusing. Care to clean that up a bit?
