KornFlakeZ »
https://forums.nicoclub.com/kornflakez-u193168.html
Thu Jul 26, 2012 12:42 am
i would suggest you do a power balance test
Originally posted by robomatic12:
Pull the coilpack connectors one at a time and listen for an RPM drop. If pulling any connector does not drop the rpm it is not firing. Then we can further diagnose if it is a fuel or spark issue.
When you find the faulty cylinders, check if they have spark by swapping the coilpacks with a known good coilpack and see if it makes any difference. After checking it has spark, check the injectors by placing a long screwdriver ontop of the injector covers and place your ear on the screwdriver and listen for the injector working. Your going to want to hear a " twak twak twak " sound. If no sound is heard, then you have found a faulty injector and should be replaced. Repeat on all faulty cylinders. Hope its helps!
