Koma Wolf wrote:Awesome, thanks for the wiring diagrams.
Looks like my TPS plug is good. Just weird to have 3 pins going into a plug with only 2 terminals.. Still need to test the TPS itself though.
I replaced all vacuum lines minus the AIV ones that go behind firewall. I clamped all new (larger) vacuum lines, even threw some clamps on lines that previously did not have them.. I ran a vacuum test got 16-17psi on both sides of the plenum, stays steady at idle, when throttle is opened it dips a few psi then ramps up. Can't hear any hissing, checked block off plates, those are good, checked bung in exhaust mani, that's good too. I think vacuum system is fine. I used all new OEM gaskets on intake manifold, throttle bodies and aac; tightened bolts to torque spec in FSM. For the block off plates and bung I used permatex aviation form a gasket... I replaced the O-rings on the balance tube as well.
EGR temp sensor is gone, I have a resistor on the way to stop the CEL from popping up (comes on every other start up)
when i first fired it up after the cams/injectors it ran decent and got it timed to 15 btdc all my marks are lined up. also when i hit the accelerator my a/f goes to and almost perfect 14.8-14.9. once it returns to idle is when the really lean a/f 21.0 and miss fire appear.centralcoaster33 wrote:Is it possible that cam lobes aren't in proper timing position? Or did your car run fine after the cams and injectors for a while, then something else happened?
Thanks, I have check the timing and it seems to still be dead set. I'm on my way to the car now so I'll try re setting the iacv. If that doesn't work I'll be pulling the manifold and "starting over". The tb's have never been touched so I can't see that being an issue but at this point I have no f'ing clue!centralcoaster33 wrote:Have you thought to start over with the idle adjustment on the IACV? I mean, if it's nearly unscrewed, maybe it's past the point where it should be. I only say this because it's happened to me. So, you screw it all the way back in and start over with slowly unscrewing it until it holds idle near the proper RPMs... while checking timing, possibly twisting the distributor as needed. Also, I know I have a 240 and not a 300 zx, but there is like a tiny screw on the TB that adjusts the idle location of the butterfly and that would have an effect on idle air as well. They're not supposed to be touched after being set by factory, but sometimes, someone messes with it and it might need a slight adjustment. Have you looked there?
