I wanted to update this thread...since it seems to have a few people following...I made a copy of the TSB that pertains to the problem with my car. I will post that in here later.
My car has been running worse and worse, especially in the lower rpm range (again.) I can feel it getting progressively worse with time. Now my ignition timing is back to about 11 degrees before top dead center. Because I can't adjust the CAS any further to fix the timing, I decided to pull it off and inspect everything. I looked at the index pegs; they are little half moon shaped roads that connect the spinning camshaft to the stationary CAS, causing the CAS to spin with the camshaft.
The index peg on the CAS was worn down, it looked as if it was slowly ground down on one side, causing it to change the shape, and preventing it from "meshing" with the camshaft, therefore it throws off the timing.
I'm pretty sure this verifies that I do have one of the early, badly machined left heads. Which is BS...its not my fault Nissan epically failed at this. Anyways, I have 2 options now...replace the CAS with another good one and see how long it stays in time, if at all, or (hopefully not) R&R the head. I checked out the flat rate labor time for a head job...17.5 hours. Ouch.
Here's a link to another thread I made, which includes pics of the index pegs on the cam and CAS.
http://zclub.nicoclub.com/zerothread/488085
Also, here's a copy of that TSB about the heads that were machined wrong:
