98TURBOKA wrote: My question is is the gear ratio different or not.
The ratios are the same (4.08:1). The Turbo 300zx has a smaller ratio (3.62:1 I believe)
Quote » I checked everything that I knew to check, and I thought that they were the same, but I figuared that being a 300 vlsd that it would be stronger. [/quote] As far as I know they are the same internally, the only difference being the output flanges for the half-shafts (5-star pattern on the 300, and 6-bolt triangle pattern on the 240) but I could be mistaken.
