Yep; 1 - Your battery was dead. You should be in the green now.
2 - The dropped cylinder is just a coincidence. You already figured out which cylinder it is.
Pull the spark plug out, put the spark plug into the coilpack, and lay the spark plug threads against the plenum.
Pop the fuel pump relay (by clutch pedal) or fuel pump fuse (by battery) out. [
http://www.youtube.com/watch?v=bLuw65cUEa8]
Have a friend turn over the engine and watch that spark plug to verify spark.
While the spark plug is out, compression test that cylinder.
Good spark, Good compression = Bad fuel.
Check the injector connection for corrosion and clean accordingly.
Ohm test 10~14ohm.
If failed, replace the injector. (I suggest always pulling the plenum to check the valve cover seals and other hoses, doing a coolant bypass if it was never performed, etc.)
Welcome to Nico!
