Honad wrote:More fuel is not the answer yet. There are several other mods that you should think about before upping the injector size. Once you reach the point where there are no many power adding or freeing "easy" bolt on's (intake, exhaust, headers, mid pipes, ecu, flywheel, driveshaft, crank pully, ignition) then it's time to start monkeying with the fuel delivery.
