1990 300zx check ecu got a code 22 car not startng
my1990300zx
Car: 1990 300zx non turbo 2+2
Car still not starting after i install fuel injectors i check ecu getting a code 22 that doesnt make sense I dont see it on my chart it flashed two times pause then two flashes again .
The car ran before had two bad injectors after i replace them, and install everthing i get cranking over and check fuel have that but no start and a weird ecu code 22. 1990 300zx non turbo
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Code 22 is the ignition circuit = PTU. Check the connections at both ends of the PTU as well at the COP's might just be a loose, dirty or damp connection.
DCaff300ZX
Car: .
1993 CRP TT- Modified
+1 for the two PTU connectors in that ridiculous harness, they will be corroded with the green gunk most likely and will work for long periods, but then one day...and usually like yours, after repairs.
my1990300zx
Ok will check thanks nice photo
my1990300zx
it was CAS connection thank everyone for your help
DCaff300ZX
Car: .
You are welcome, congrats on the fix and enjoy!
