1990 300zx car horn goes off when battery's connected
300zx1990z32
Car: 1990 300zx (z32)
one of youngest Z owner's only 14
my car's horn goes off when i connect the battery, hood not bolted on but i still latch it, engine ran perfect before this, cant start they engine because of this please help asap!!!
Thanks, Sam :)
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Your factory alarm unit is engaging the killswitch, most likely because of the hood sensor switch. Try putting the key in the driver's side door and turning the key clockwise (unlock) two times, to see if that disables it. If not, you're most likely going to have to disconnect the factory alarm unit, at least until you can figure out which sensor is causing the alarm to trip (most likely hood sensor switch). The alarm controller is located above the ECU, under a bracket. Unplug it and you should be fine.
