nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue May 22, 2012 8:49 am
Have you checked the CAS? Its the round piece that is on the front of the engine, driver side. You can physically take it out, turn the part going in the engine and should hear each injector click, make sure the key is to the on position. If the injectors don't click, make sure they are not gummed up and ohm correctly, between 10-14 ohms.
Do you have access to another ECU? Just reread your second paragraph, since it does not do self diagnostic, I would say it is bad. Where are you located? What year is your car? I do have an auto ecu from a 92 just lying around in my garage. It was left over when I did my tt/5 speed swap.
