Thank you for your hospitality and your quick response! Maybe I did a poor job of explaining the "streering shaking" problem, so here are some more details as to why I believe it's a rotor problem. When I changed the rotors, for the first month I was in heaven cuz there were no issue when breaking, no shaking in the streering wheel, etc. After about a month, I started noticing steering wheel shaking, and as time went on, it became worse and worse. Thus I assumed it were low quality rotors that warped within a month or so. If you still think it's a "tension rods" or "tie rod ends" problem, I could have my Z inspected for that.DCaff300ZX wrote:Welcome!
My NA at times would stop registering miles, as the odometer wheels would bind somehow which a quick jab from the reset button would fix...when I noticed it. Not much you can do there.
As for the "shaking" that's not a rotor issue which may explain Nissan's reaction, as their rotors are fine and I don't know the term "caving". The shaking can come from bad tension rods (common) and also perhaps worn tie rod ends, or both. Bad shocks can also make things worse and the suspension wears similarly so I suspect that your Z needs attention to those areas, which may solve your problem or highlight the actual issue.
Good Luck!
It happens ONLY under breaking. All non-breaking times the car is perfectly stable. I drive the Z at aggressive speeds (sshhhhh, sometimes ~100-120MPH) without any issues. So, it's definitely an issue associated with when I put my foot on the break pedal.grayman_TT wrote:It wouldnt hurt to check all the bolts and make sure they are tight.
Does this only happen under braking or all the time?
This is awesome information, Dave! And it's great to know you've personally dealt with a VERY similar situation on another 1990 Z and it turned out not to be the rotors. Your DIY project is easily doable by a novice like me, and that's what I'm going to do over the coming weekend and share with you what I found. Thanks a lot for your help; it's truly appreciated!DCaff300ZX wrote:I took a test drive once with a guy with a 1990 who claimed brand new complete (caliper/rotor/pads/M/C/booster) brakes all around (and after the ride I checked- seemed new) the car would do exactly as you said- ONLY shudder when braking medium to hard and coming down from speed (he was an excited driver, 80+ often). He also claimed new ball joints/LCA's as well but said the rest was original...tie rods, FUCA's, and tension rods, the high wear items BTW.
You can DIY roughly test them by jacking one side of the car CORRECTLY (jacking points under car) enough to release one front tire and leave the other with resistance, "steering" the wheel by hand back and forth any play felt will be the tie rod end(s), or a broken steering rack. Oh, and the rack bushings (loose, missing) may also be the issue which is also somewhat common in higher mileage Z32's.
Also, with the wheel up you can try to "rock" the wheel in and out gripping the wheel and lifting with your leg, testing whether or not the Front Upper Control Arm (FUCA) is worn out and loose, EXTREMELY common. When one thing goes out in the Z32 multilink, everything else needs looking at also.
IMO everything mentioned points to a serious inspection of your front suspension, the multi-link style with it's preload effect makes each part have to handle it's load and do it's thing correctly for it all to work well- so there's my argument as best as I can make it. Hard to see new rotors warping enough for headshaking without some other serious brake problem with the caliper sticking, or M/C issue.
I took your post to my trusted mechanic along with my Z, and he performed a complete suspension check and informed me that it is NOT the suspension, but the darn ROTORS! And then he took me inside the garage, and showed me the problem. With the car up on the lift, he asked me to move the front tire - the tire would not complete a single revolution, and would get stuck mid-way. Basically the highs and lows of the rotors warped, and were making the wheel stuck at certain points of the revolution. I had to put so much force to make the tire go forward and complete a revolution. I found this to be the case on both front tires. So, the decision is to change the front 2 rotors and pads.DCaff300ZX wrote: You can DIY roughly test them by jacking one side of the car CORRECTLY (jacking points under car) enough to release one front tire and leave the other with resistance, "steering" the wheel by hand back and forth any play felt will be the tie rod end(s), or a broken steering rack. Oh, and the rack bushings (loose, missing) may also be the issue which is also somewhat common in higher mileage Z32's.
I have a few friends using STOPTECH, and they've all been happy. So, I'm leaning towards STOPTECHs.NolimitZ32 wrote:oooh upgraydd (with two Ds for a double dose of his pimpin).
STOPTECH all day.
also have a gander at these: http://www.z1motorsports.com/product_in ... cts_id=138
Awesome info, I learned something there and appreciate it!gugga4u wrote:I found this article to be the final nail in the coffin:
http://www.twinturbo.net/ttnetfaq/FAQpa ... rping.html
This article has ALL the signs that were with my car for the past year w.r.t breaking/shimmying/shaking/etc.
I had my local mechanic install the following today (4/27/15) with instructions from the above article, and will update this post after a month to see how they rotors/pads are holding up:
Pads: Hawk HPS Street brake pads (Performance Street)
Rotors: Centric High Carbon Plain 125 Series Rotor (Premium, Performance Street, Autocross/Track)
Thanks for everyone's help!
