VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Jan 23, 2023 8:50 pm
That test you were looking at is to see if the field coils are healthy, not to test for a short. To make smoke the short has to be pretty severe, so if it's in the alternator it's a collapsed brush or something else catastrophic. See if the short goes away with the main alternator terminal disconnected. If not, see if it goes away with everything else on the alternator disconnected. If either of those kills the short, the alternator is bad. If not, with the alternator still disconnected, disconnect the alternator main fusible link and ohm from the alternator main wire to the block. That should read infinity (or at least megohms). If not, there's likely a short in your old wiring. If that tests good, your short is elsewhere.
