1990 240sx wont turn over?
chrisberb
Car: 1990 240SX Hatchback
i recently purchased a non-running 1990 240sx for a project car. it has been sitting for about 2 years, ran before it sat. the owner said it started about a month ago with starting fluid but wouldnt stay running. they suspected fuel pump. i now own the car and upon trying to start it up get nothing. the lights and bells come on, but all i can hear under the hood is a soelenoid click or something of that sort. this is my first import project car. i am used to working on motorcycles. does anyone have any suggestions on where i should start looking? thanks, chris
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
hit your start with a hammer while someone is "cranking" the key, if it starts your starter is seized. thats what it sounds like to me. also if you want to get balzy, run a jumper wire from you positive terminal to the thin wire coming out of the starter, if the car tries to turn over, the roblem is in your colum. if it doesnt your starters bad or your wiring to the starter is bad. If you get 12v+ with a volt meter at the fat wire on your starter(red to the fat wire, black to ned on battery) you know that the power feed for the starter is good. do thoes tests and tell us what happened.
vancouverbc
Car: 1991 240sx
battery
chrisberb
battery is good. i had to manually push the clutch saftey switch and then it turned over really slow about half a turn. thats all i got. on another note, now i know that my clutch master cylinder is locked up and thats why the pedal wouldnt depress enough to hit the switch. any ideas on that? new one is only like 25 bucks. at least i think its the master, could be the slave tho i guess. know any easy way to check that out? thanks guys
vancouverbc
Car: 1991 240sx
http://www.nicoclub.com/FSM/240sx/1989-90/
this is the fsm. your car is turning over so that is the end of what i know
Dark_Joker_Samurai
Car: 1990 Nissan 240sx ka24de
try cleaning your battery terminals.
chrisberb
yeah they were clean but someone had put some type of grease on them that wasnt letting them make a good connection. I wiped them out really good and now we are in business. thanks guys. that problem is fixed.
chrisberb
okay now car turns over, but sitting overnight, something is drawing power and killing the battery. it goes from 13.1 volts to less than 2 by morning. any ideas on what would cause that. no interior lights are staying on.
lbrowne
If you battery is bad it will lose power. You should have more than 13volts when the car is running (although you didn't say when you got that reading)
Either fully charge the battery properly with a charger or try a known working good battery.
A bad battery most times can easily power stereo and dash lights.
chrisberb
i repaired a bad fuel pump power wire and got everything ready to run. had battery charging on a battery tender all week. it had 13 volts out of the car. car would then turn over and start for about 5 seconds at a time before dying. restarted it about 6 or 7 times thinking it was just working air out of the freshly filled fuel lines. then went to start it on the 8th try and just heard a click and the car wouldnt turn over. recharged the battery all night and still got the same click in the morning. any ideas
vancouverbc
Car: 1991 240sx
driftking91
Car: 1991 240sx
Wha
funigui wrote:hit your start with a hammer while someone is "cranking" the key, if it starts your starter is seized. thats what it sounds like to me. also if you want to get balzy, run a jumper wire from you positive terminal to the thin wire coming out of the starter, if the car tries to turn over, the roblem is in your colum. if it doesnt your starters bad or your wiring to the starter is bad. If you get 12v+ with a volt meter at the fat wire on your starter(red to the fat wire, black to ned on battery) you know that the power feed for the starter is good. do thoes tests and tell us what happened.
What is a colum?
iwantasileightysr
Car: 91 rps13
did you check your clutch sensor again. im sure you already did but i thought i would add that.battery terminals. again
couldnt be the column if its sending power to the crank relay to click
