1990 240sx wont start
oncecamhatch
Car: 90 nissan 240sx
1990 240sxKAeMy car wont start. It has power to turn on the dash lights and other lights, but it doesnt do anything else. theres no clicking or any other noises when you turn the key. It wont push start either. im lost please help.
BlackHat
Car: 1989 Nissan 240sx Hatchback
Are the headlights bright or really dim? Have you tried to have someone give you a jump? Did you give the engine a once over to see if anything has come unplugged?
Just mentioning the basics. Beyond that you would probably need to find out how to tell if the starter itself is dead or not.
jdm_lover
Car: 91 240
no matter what...it cant be the starter if it wont jump start.....cause it should jump start iff the starter is bad....i have the same problem as you are bro....lets solve this out...it wont click right? well check out your ignition wires. and look for a black/yellow wire...and see if it is cut or not and reconnect it and see if it cranks...might be it...for me i just got my car to crank from where your stage is at...but mines not starting ....just cranks....
BlackHat
Why couldn't it be the starter if it won't jump? I'm not disagreeing because I don't know a whole lot, but I was under the impression that the starter being bad would be a reason you couldn't jump start?
jdm_lover
Car: 91 240
your car should be able to be push started even if your starter is bad if its a manual...but if it doesnt push start then its not your starter...could be too but then the starter wouldnt really be the problem...check your relay switch...or your ignition switch...
