1990 240sx vlsd swap
Zlows13
Car: 1990 Nissan S13
Want to swap a vlsd in my 1990 240sx. Just curious if the 180sx lsd will bolt right up or will I need to get a couple of other things?
Reason: Moved to correct forum
NukeKS14
Car: '95 Nissan 240SX SE KA24DE-T
AC Cobra Mk IV Rep.
2020 Honda Civic Si
It depends... Does your car have ABS/HICAS? does the donor car?
http://www.texasnissans.com/tx/forums/s ... hp?t=12855
^there's a great source of info for the vlsd swap for an S-chassis. All USDM sourced vehicles. Depending on what you get, it may be as simple as swapping your diff cover, or as complex as either replacing axle stubs and/or axles and getting a new driveshaft.
I don't generally like redirecting away from the forum but that's about the most consolidated place I've seen all of the R200 swap info.
Cliff notes (assuming a VLSD from a J30, Z32, or S14 w/ ABS
If you own an S13 (89-94) you will need to swap the rear cover off your stock open diff onto the VLSD:
The S13 uses a different bolt pattern (4 bolts) than the S14 (2 bolts) on the rear cover...
You will also need 2 longer mounting bolts for the S13 chassis, and 2 large washers for the front mounts...to be used with the large bushings on the front mounts.
They are M12 X 1.25 thread/pitch, 85mm long.
The stock S13 front mounting bolts are not long enough for the J30 and S14 diff mounts.
And I've seen more than few diffs drop out from the front mounts by not using washers - They need to be ~1.5" diameter or so, and 1/8" thick.
To overcome the .75" extra length at the nose of the diff you can:
1) Install it and see if your driveshaft and transmission mounts have enough play to soak up the extra length.
2) Get a driveshaft from an ABS equipped 240SX...it's .75" inch shorter.
You can also swap the VLSD "guts" into your stock open diff housing:
If you buy a J30 diff but would like to keep the stock 4.083:1 ratio...open it up, remove the VLSD center section, and swap it onto your open diff ring gear.
Sounds easy, but it's a time consuming process, and if you mess it up (have too much or too little clearance or backlash) - You'll ruin the gearset.
I've done it twice succesfully, so it's not that hard or scary...but you need to take your time and put EVERYTHING back EXACTLY where it came from (shims, bearings, etc...).
And to make it VERY clear...you use the VLSD center section AND output shafts...with your stock open diff ring and pinion / case / bearings.
Gear lube:
You don’t have to use a fluid designed for an LSD as the R200V uses a sealed unit.
Nissan recommends 80W-90 oil, 1.5 liters (3 1/8 pints)...
Do you already have a 180sx diff or something?
