Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat Aug 06, 2005 8:02 am
Try shifting with the engine running, except do not push the clutch pedal in. If you can shift in and out of the gears it is most likely a clutch or pressure plate issue. If you grind, then it should be a transmission problem (though you dont want to grind for more than a milisecond). It could however be either or both if you have serious enough internal transmission damage...
